Oct 24, 2013 4:28 PM UTC
How can minerr() follow constraints to select parameters?
- 3 replies
- 1519 views
- Translate All
Hi:
I try to use minerr() to decide parameter x1,x2,a2 with a minimum error.
Based on the result, the error was reduced from 3.391 to 3.373 (not that significant)
The problem to me is that minerr() didn't follow constraints to select parameter x1,x2,a2 when I look at the datalog (minerr log.txt)
What should I do to let minerr() follow rules of changing x1,x2,a2?
