How do I create a table that requires calculations with different variables?
Hi Mathcad 10.0 Prime User,
I want to make a table with different variables. My Q is always different, on which the other variables depend on. Q has to be 2 or higher. So if someone can just show me how to do the basic table, I will than use my Q's etc. I really have no clue how this might work in Mathcad.
File is attached.
Thanks.
Saro
Werner_EAnswer
There are a few pitfalls along the way.
The Solve block solves for two variables, but Prime does not allow vectors that contain function definitions.
You could do it like this:
This function with both values as the result could now be broken down again into two individual functions. Since the Solve block sometimes does not find a solution (for values of Q less than 0.809993 m³/s), this error can be intercepted using try..onerror:
Now you could use the functions for plotting,
but of course you can also use them to create a table of values
EDIT: Just noticed that in the picture I forgot to add the unit for Q in the header text. Is fixed in the attached file.
Prime 10 file attached
You have to turn the expressions which are dependent on Q into functions of Q.
This also can be done using the solve block -> Parameterizing Solve Blocks
BTW, your thread
https://community.ptc.com/t5/Mathcad/How-to-find-two-variables/td-p/1021425/jump-to/first-unread-message
still is not closed.
If there are still any questions feel free to follow up. Otherwise consider to close the thread.
Thank you I forgot to close it - i closed it now. I will try your request.
Thank you for now.
But this doesn't calculate my individuelle variables in my table. Do you mean I should write Q1 = 2, Q2 = 2 and so on, but I wanted it to be less typing - so that they is a shorter way. I was thinking doing it maybe with vectors. that I say my Q :=1...10 (until whatever number), but that doesn't work with units. So that it gives me all individual variables in the table. I am not a native speaker - I can't really say it the way I want to.
I might not understand what you mean. I kind of don't get it with the link
