How do i type .. N*+4=B in mathcad
Hi
Does anyone know how i can type:  N*
-MFra-
you can only write variables or constants with a subscript. The asterisk can not be used since it is a math operator. You can use it in text format.
dprasad-21-VisitorAuthor
Its a bit odd. I was hoping that my equation look similar to as/nzs design standard code variables.
N* is all over steel, concrete and timber design standards.
It would then be much easier to share the cal sheets.
What version of Mathcad are you using?
Version 15 ... 2015 version
In Mathcad 15 you can use "Ctrl + Shift + j" and "Ctrl + Shift + k" trick:
Why not?
OK, here are my tries.
The first one being exactly what Luc suggested.
The second one a bit problematic in use as its not a variable name but a math term.
All have in common that have to do a lot of work to achieve a mediocre result.
EDIT: Just see that Valery had beaten me by some minutes concerning the second method. Of course he is joking with *:=3
