How do you get units to show up correctly in x-axis using Mathcad Prime 3.1?
I am able to have units show up correctly in the y-axis but when I put seconds in the x-axis, it adds 1/s to it.  Does the x-axis have to remain unitless?
23-Emerald I
Interesting!
Try adding:
      Time3 := Time3*s
mepp1-VisitorAuthor
That does seem to fix how the unit is displayed in the plot.  It is a little weird though, because it still works even if I take the unit off of the ReadFile callout.  Is this just a bug I wonder?
23-Emerald I
Apparently Prime was not assigning units in the READFILE statement.  (Odd, it assigned ppm.)
Prime does a lot of "labeling" to things: Automatic, variable, unit, constant, function, system, and keyword.
Most of the time when I come across this it tracks back to a label that isn't right.
If you evaluate Time3, what does it show for units?
mepp1-VisitorAuthor
If I evaluate Time3, it doesn't show a unit.
If I try to add a unit to it, it automatically adds (1/s)
It looks like a bug to me. It's not applying the unit in the READFILE statement. Strange, since it seems to apply ppm OK. Try applying kg as the unit, and % as the unit, and then evaluating.
