How do you set Y-Axis Limits in XYPlot in Mathcade Prime 7
In Mathcad prime I added a plot that needs y axis in the logorithmic scale, which I can do, but values below a certain point are meaningless and destroy the shape of the plot. Is it possible to set the Y axis limits in a Mathcad Prime 7 plot? Grid lines would also be great.
terryhendicott
You double click on the end markers of an axis.  Number is grayed out so you can change the number.  Not sure which version of Prime this was implemented in?
The plotting in Prime is one of two options Plots | Traces | Insert Plot or the Math | Regions | Chart Component.
In Chart component grids are possible. In "Insert Plot" grids are not defined by Prime.
Two options to proceed are possible.
a) Change to a Chart Component which has grids.
b) Research the community where LucMeekes and Werner_E have made grids possible in the "Insert Plot" plots
Enclosed is Werner's
