23-Emerald I
How strong is the correlation
I have a system that has a number of thermocouples that is reporting a thermal strain. The strain appears to be dependent on the thermocouple readings, but not all of the thermocouples will affect the readings as much as some others.
Given a dataset, how can I rank the influence levels of the thermocouples?
23-Emerald V
Principal Component Analysis?
Stuart
Plotting a 'points' type graph of the strain against the temperature for each (single) thermocouple should give a quick (and dirty) view of the relationship to each probe.
no effect / linear / polynomial / exponential ...
from that you should be able to minimise thenumber of probes to consider & the next steps will depend on what outcome(s) you need.
If the data is in an array / matrix then it should be possible to create the graph with an index to step through the probes one at a time to minimise the overhead of multiple graphs.
Regards
Andy
23-Emerald I
Regards
Andy
Would that it were that simple!! The attached file has my data set; it's difficult to pick out which temperature measurement is most responsible for each measurement let alone decide on a function type.
Hi Fred,
If I understand correctly, you have 32 thermocouples, 16 outputs and the data is 8 runs that have been added sequentially to the dataset.
Taking one condition (at "random" , honest).
output 1 and thermocouple 10:
Video Link : 5361
most of the runs show significant change in stress for no tc change , but run 6 seems to show a linear dependance & run 7 a step variation.
Now , I may not have seperated the runs correctly & this may lead to oddities. But given the inconsistency in this run , it might be adviseable to look at the data for each run independantly.
Andy
