How to avoid wrong branching?
it took quite a while before I found out the Mathcad 15 may have a big bug with if - otherwhise...
After introducing an one line statement using if, the next standard line holding an if-otherwise construct was not executed if the first condition was true. This happened two times in the code!
I have to say that this akward behavior makes it more likely to stay away from ptc as much as possible...
