How to change the size of an already defined array.
I am using Mathcad Prime 5.0 5.0.0.0
I have a worksheet with an array that is 12 rows by 1 column. I know realize I want 15 rows. How can I change the arrays size so I can enter the additional values?
    Hi @cwenner-2
    Please check the attached video.
    cwenner-21-VisitorAuthor
    Hi- that is fantastic in MathCADPrime. Good to know since I have a personal copy at home. However, the version we use at work is MathCAD 15.0! I did not see the same type of option under the >Insert menu, nor when I opened the "Matrix" tools.
