Jul 15, 2024 10:31 PM UTC
How to convert mathcad prime 10.0 file to prime 9.0?
Hello PTC Community,
I had calculations in Mathcad prime 10.0 version. When I am trying to open the sheet in prime 9.0, it gives me an error message that the file is not compatible as it is written in the latest version.
I would appreciate if anyone can help me.
Abdur
Werner_EAnswer
Jul 15, 2024 11:48 PM UTC
There is no officially supported way to convert a sheet to the format of an older version.
You can install both versions and use them side by side. That way you could open your P10 sheet and create a new P9 sheet by copying the regions from the P10 sheet to the P9 one.
Unfortunately as its a PTC software this only works one by one and not with all regions in one go. Even worse when it comes to text regions - you can't copy the whole region, but at least you can copy the text. Similar but a whole lot worse for solve blocks as you must first create an empty solve block in the P9 sheet and then copy the regions within one by one.
Needless to say that you also have to manually adjust the formatting in the P9 sheet to match that in th P10 sheet.
But users like @LucMeekes  have found a way to do a conversion by manually editing the underlying XML files. Maybe he can be of help to you.
Actually a Prime file is a zipped directory made of up of a couple of xml files. You can rename a *.mcdx file to *.zip and unpack it to have a look.
Werner_E25-Diamond IAnswer
Community Moderator
Jul 22, 2024 12:11 PM UTC
Hello @Abdur_2063,
It looks like you have a response from a community member. If it helped you solve your question please mark the reply as the Accepted Solution.
If you found a solution, please document it in this topic and mark it as "Accepted solution".
Vivek N.
Community Moderation Team.
