Apr 1, 2016 4:46 PM UTC
How to convert XMCD file into MCDX format?
The file is from Mathsoft MathCad, but I want to run it in the new PTC MathCad what is the solution please answer ASAP. And are the two software same?
VladimirNAnswer
Mar 17, 2020 8:29 AM UTC
Here it is.
Apr 9, 2022 7:11 PM UTC
Hi, can anyone help me with converting this file to mcdx format? Thanks 🙂
Apr 10, 2022 6:48 PM UTC
Please find it in attachment.
Apr 10, 2022 8:33 PM UTC
Thanks mate 😉
May 21, 2022 8:03 PM UTC
Hi, can you please help me with these files? Thank you !!! ❤️
23-Emerald V
May 22, 2022 7:05 AM UTC
Here you go.
May 22, 2022 8:33 AM UTC
Is it not compatible with Mathcad Prime 7 ? I only have this in my pc and also Mathcad 14. I can't convert them from Mathcad 14 into Mathcad Prime 7, because I only receive the error with the NET Framework 3.5(it is not enabled) but it is enabled in my pc, and still having this issue.
Thanks. ❤️
Jul 18, 2022 3:05 PM UTC
Hi, may you please help me convert this to a .mcdx file? Thanks!
23-Emerald V
Jul 18, 2022 5:20 PM UTC
You should state which version of Prime you are using with the converted file.
Here it is saved as a Prime 8 file. Note that the file references another, named: 97stm.mcdx
You may need to provide that file as well for conversion...
Jul 18, 2022 7:18 PM UTC
Hi Luc,
Sorry, I didn't notice that the version of Prime makes a difference. I use Prime 7. I've also attached the file that is referenced in the worksheet.
Thanks!
Aug 21, 2022 12:52 PM UTC
I just started to do my old school job and I have old file of xmcd. Can anyone convert this file to mcdx? Thank you! 🙂
Aug 21, 2022 1:00 PM UTC
Here it is.
Oct 10, 2022 3:14 PM UTC
May you please help me convert these files.  I use Prime 7.
Thanks!
23-Emerald V
Oct 10, 2022 3:28 PM UTC
Same question you asked last month and three months ago (here).
Your set of files relies on 97stm.MCD which contains password locked areas. These cannot be converted to Prime. You first have to open the locks, and you need the password for that.
Oct 12, 2022 11:52 AM UTC
Hi Luc,
Can the other files be converted though? There are 8 other files in the folder, I don't think they're password protected.
Thanks!
Nov 12, 2022 1:32 PM UTC
Hey,
can someone convert this file for me so it will be compatible with Prime 7.0?
Thanks a lot, have a nice day 🙂
Nov 12, 2022 2:22 PM UTC
Nov 12, 2022 5:29 PM UTC
So you are not going to do that? I have no license for that old one and i don't know where to get it 😞
Jun 12, 2023 4:20 PM UTC
Hello. Can someone help me to convert this file into .MCDX?
Thank you very much.
Jun 12, 2023 5:19 PM UTC
You sure attract more attention if you open a new thread with your plea and don't use one which is already flagged as "solved".
Its also very important that you state which version of Prime you are using because the file format changes with every version!!
Why do you need us to convert the file?
If you are using Prime version 7, 8 or 9, you can chose to install a converter so you could do it yourself. If you missed to check the option to install the converter, you can re-run the installation file and add the converter.
If you are using Prime 6 or lower, its even more important to tell us which version.
