How to copy data in MathCad prime 6.0
I would like to ask how to copy data from one table to another table? In version 15, the CtrC and CtrlV command worked. Unfortunately, this feature does not work in MathCad prime 6.0.
Thank you for answer. JV
23-Emerald V
Hmm, what does not work.
The data of list A of the left table was selected (all three items) and copied, then pasted to the first item of the unnamed left list of the second table.
Then the top item from that list was selected, copied and pasted to the top item of the right unnamed table list.
Finally the last item of the list B was selected, copied and pasted to the second item of the right unnamed list.
Again, what doesn't work, apart from the fact that Mathcad 15 does not have 'tables' like Prime offers them...?
Thank you much for your answer but unfortunately our problem is slightly different.
We have problem import data fro text file to MathCad.
Here the command CtrlC and Ctrl V does not work.
23-Emerald V
I suggest you try the built in functions READTEXT, READFILE or READCSV to accomplish what you need.
