How to create a vector with the minimum values of two other vectors?
If I have a vector A and B both with 10 elements. How can i create a vector  C that has the minimum values of A or B on each corresponding position.
Thanks in advance !
Werner_EAnswer
Use vectorization.
But as min can't be vectorized, we have to write our own min function, calling the built in min.
Werner_E25-Diamond IAnswer
Use vectorization.
Short, simple and clear . Thank you very much
