How to delete files from Mathcad15?
Can I use VBA script to delete xlsx files from inside Mathcad?
Hi ,
there was an old thread to delete files.
either
search "delete file"
or try
http://communities.ptc.com/message/157493#157493
regards
Andy
What does you mean by delete xlsx files? Do you mean references?
An excel file in xlsx format
23-Emerald V
Yes, you can. Use a scriptable compononent - typically the button or tickbox control, right-click on it and choose Edit Script from the context menu. Then write your VBScript to delete the files. You can set up the control so that you can hard code the list into the control or create an array of files names in Mathcad and pass that array to the control (as an input).
Stuart
