How to Display Image with If Function
Is it possible to display image with if condition
I would like to display the right side image if the left side condition is satisfied.
Could you please advise.
BR,
J.Randeep
23-Emerald V
Something like this?
Mathcad 15 only ... You're out of luck if you want to work with images in Prime.
Stuart
Mathcad 11-15
One Mathcad-Web-Sheet with this trick - pictures - formulas for calculation
http://twt.mpei.ac.ru/MCS/Worksheets/Chem/CRC.xmcd
23-Emerald V
Stuart
Since this conversation had taken place in 2016, I wanted to raise the question. Has PTC implemented the Image addition like the one we see here in Prime yet or not? It will be very disappointing if they have not yet included the feature to go through images select based on If statement.
Thanks;
Kadhir
No, nothing comparable is implemented in Prime.
ttokoro
Edit: Add notes to EXCEL component.
t.t.
ttokoro
Not image but graph of EXCEL that selected by ComboBox of Prime 9 and show it Prime sheet by EXCEL compoment.
Now no need to use chart component if you can use EXCEL to plot the graph.
t.t.
