How to display only the output of an equation.
Is there a way to display only the output of an equation? For example, if I define:
hstuecken_0-1585861264057.png......
Is there a way to only display the 93.6% later in the document? Without having the variable, Mcw_C6_V, displayed? I would like to summarize my calculations at the bottom of the document but allow them to change automatically if I change calculations earlier on in the document.
LucMeekesAnswer
23-Emerald V
It is possible, and fairly easy. Prime 4 file attached.
But why would you want to present just numbers?
23-Emerald I
I don't believe sp.
it is possible with the use of controls. I've added a MC15 sheet that shows how to do it.
Cheers
LucMeekes23-Emerald VAnswer
23-Emerald V
23-Emerald I
Very clever, chicanery worthy of Val Ochov!
Thank you very much Fred. Attention from your side counts twice.😊
