How to edit excel table parameters?
I have embedded excel table with data and I export them to matrix of  variables (vectors) and I don't know how to open an editing window to assign rows/collumns of table to these vectors?
I also had this issue in the past. It sometimes appeared and I right clicked the table and I have chosen properties option. But now I can not get it.
I hope someone faced the same situation and knows solution.
Thanks in advance for any help.
terryhendicott
Which version are you using, Mathcad 15, or one of the Prime releases?
How did you set up the excel table?
Cheers
Terry
I use Mathcad 15.
It happens when I want to edit somebody's document. When I do it from scratch it works normally but I want to edit already created table I have no access to those option.
My colleague from work found the way for it by copying it to new document and it works in  new one and then bring it back to original document.
But I am looking for the way to do it without all those tricks.
23-Emerald V
Can you attach the sheet?
That way people helping you can have a look.
If you're not allowed (to prevent IP disclosure) to attach, create a simple sheet with the same problem.
