how to find the matrix element that contains the minimum or maximum value in the matrix?
Obtaining the minimum and maximum value in a matrix is easy due to you can use the functions min and max.
but i need to obtain the matrix element that contains the minimum and maximum value inside the matrix.
Thank you in advance,
Rogelio
Hola Rogelio. Muy buenas tardes.
Alvaro.
Alvaro.
Sorry, but your question is not clear. Does this answer it?
If not,please clarify what you are looking for.
Alvaro and Richard,
thank you very much for your answers, both are correct!!!
but i could only marked one as correct.
one more questions, where in the help i can find this type of responses?
Best regards,
Rogelio
Thanks! Actually, Richard have too many points!
This kind of brief solutions can be obtained from mathcad's electronics ebooks, but don't know in prime versions where are they. That's include, for example, some very old versions of mathcad, like smath (believe, can't remember the name very well) with solutions for high school problems, or the Schaum series, solved in mathcad. Recently, I see a pdf with the teacher solutions from an undergraduated textbook, all write in mathcad, 14 or 15.
Also, forum, even don't have very well search engine, can help, I think. Or use google "in-site" search engine too.
Best regards.
Alvaro.
