Aug 1, 2023 1:30 PM UTC
How to form a matrix with variables defined with range?
I want that x and y to be in a single matrix with 2 columns:
Werner_EAnswer
Aug 1, 2023 10:28 PM UTC
Nice idea!
Your approach works OK as long as "last" is not actually a member of the result vector
but it fails if it is
For the example given it works OK, though,
but the reason is a round-off error which forces ceil to return the correct number 401
Using floor(...)+1 instead of ceil(...) should fix it (unless we find an example with a numerical inaccuracy in the opposite direction)
EDIT: And the example wasn't hard to find. Both your versions (the orginal with ceil(..) and the suggested fix with floor(..)+1) fail and also my version fails 😞
A possible fix might be to to round to something like 7 decimals first and only then apply  floor(...), or trunc(...) .
ttokoro
Aug 1, 2023 1:41 PM UTC
t.t.
Cornel19-TanzaniteAuthor
Aug 1, 2023 1:51 PM UTC
terryhendicott
Aug 1, 2023 2:51 PM UTC
