LucMeekesAnswer
23-Emerald V
Something like this:
If your files are sequential in their name - "data_1.dat", "data_2.dat", etc., you can write a program loop that will read the data from each file and place them all in a matrix. This approach worked very well for me.
Hope this helps!
mzarrabi1-VisitorAuthor
Hi @ChrisKaswer. Thank you for your reply. Do you have a template to share?
LucMeekes23-Emerald VAnswer
23-Emerald V
Yes - what Luc has shared is very similar to what I have implemented. You can get a bit more complicated by monitoring the size of any data file and reading files that have different row and column counts. Units can be read-in as well with some other tricks (of course the data needs to be set-up to accommodate this), but Luc has captured the fundamental approach well.
Good luck!
