How to keep the continuity at the boundary of a piece-wise function
Hi all, I am plotting a periodic piecewise function, which has different values around the turning point. I found that the continuity can be kept at some points, while it cannot be kept. Would anybody hep me about this? I have attached the detailed question in a simple example. Thank you!
RichardJAnswer
If you quit using the quickplot feature, and define a range variable for your independent variable, a lot of your plotting questions, including this one, are easily resolved. In this case you just need more points in the plot.
RichardJ19-TanzaniteAnswer
