ttokoro
ttokoroAnswer
Using Luc's stroke data sets. Linear plot of stroke data is overrayed.
t.t.
@Cornel wrote:
The plot result should look like below: I am interested how to put that Rg/Ri on each graph.
Prime does not  support any labels in its native 2D plots. You would have to create text regions and place them manually. Given the coarse grid used by Prime even if you chose the "fine" grid this sure can be demanding.
Not sure about the Chart component which supports labels because I can't use it. I guess here you could use different colors and line styles and provide the names in the legend. Of course this means that you can't use the waterfall plot to plot all curves  in one go but rather have to plot each of the curves individually to be able to give it a unique color/line style.
Cornel19-TanzaniteAuthor
How to define a function like this? As I do not see slash button when defining a function. Right now its a text. But if you press slash button on keyboard in a math region you will get the division line.
maybe that way 😉
Start with a string by typing " and then delete the quotes. subscripts must be done after deleting the quotes.
You can create a lot of funny variable names that way, but some characters can't still be used. E.g. you can't create a variable name with a space in it or a variable name which starts with a number.
ttokoro
ttokoro21-Topaz IAnswer
t.t.
ttokoro
Only 1 x-y plot to show all data.
t.t.
