How to model a Transistor in MATHCad?
Hi All. I m trying to model a circuit which is basically a CE amplifier.
I m not sure how to start. Can anyone please help?
LucMeekesAnswer
23-Emerald V
How accurate do you want to model the transistor?
For what purpose do you want to model: Large signal or small signal (AC)?
-MFra-
LucMeekes23-Emerald VAnswer
23-Emerald V
As accurate as a Practical model. I want to perform worst case analysis as well using this model..
23-Emerald V
What do you think is a 'Practical' model?
In order to model you must have a circuit, know parameters of the components in the circuit. Do you have those?
What kind of worst-case scenario's do you want to investigate...component tolerances, environmental conditions, EMI situations?
But most importantly: why use Mathcad, and not an electronic circuit simulation application (e.g. LTspice)?
Maybe something like the attached? There're P4 so I hope you can open them.
Norm
so sorry. i could not open.
Can you please help me with this
-MFra-
Please, you should specify to whom of the community you refer.
-MFra-
