How to multiple across vectors?
- 6 replies
- 2801 views
- Translate All
In the attached MathCAD 14 worksheet I have defined two vectors and a number. Is it possible to write an equation that would provide a resultant vector in which each first position is the result of the multiplication of a number by the first position in one vector by the first postion in another vector. The second position of the resultant vector is a number multiplied by the second postion in one vector by the second position in another and so. Basically I am attempting to do this:
4 * [A] * [E] = [4*A*E]
[B] * [F] = [4*B*F]
[C] * [G] = [4*C*G]
[D] * [H] = [4*D*H]
MathCAD is performing this operation as a matrix operation which is what I'm trying not to do. I'm asking because I will eventually be using much larger vectors where I can save time and potential errors by performing it in one step and relying on MathCAD instead of writing out individual equations.
