How to multiple two vectors to produce a vector of products?
I am sure I am missing something but...
I want to multiple two vectors... Say, a vector of molecular weights times an equal length vector of component molar flow rates to produce a vector of component mass flow rates.
If I simply multiply the two vectors in MCP3.1, I get a scalar which is the sum of the products (in the example above it would be the total mass flow for the stream).
But how do I generate a vector where each element is the product of a mwt times a molar flow?
[I did look at the vector operators and functions but none of them seemed to do it.]
TIA
--Doug
You need to use the vectorise operator Available from a couple of places on the ribbon or <ctrl><shift>6
attached is Prime 2 but shows the operation
regards
ddenholm1-VisitorAuthor
Thanks... That does the trick.
--Doug
23-Emerald I
Look up "vectorize" in help, an arrow above the multiply operation
Thanks! --Doug
