20-Turquoise
How to plot a triangle of XY-plane in 3-D for SURFACE PLOT (TO FILL COLOR) ?
  Hello Everyone.
How to plot a triangle of XY-plane in 3-D FOR SURFACE PLOT IN ORDER TO "FILL (COLOR) SURFACE" TO THAT TRIANGLE ?
Thanks in advance for your time and help.
  Best Regards.
lvl107Answer
20-Turquoise
  I highly apprreciate your time and help, Werner. 😀😀😀. The method 2 that all I wish it.
     Many thanks, again.
          Best Regards.
               Loi.
basically you have the choice between creating a polygon (a couple of point which may be connected by lines) or a surface patch.
MC15 sheet attached
EDIT: You added the need for a surface plot just after I replied. But you now have that solution, too.
BTW - no need to cry (capital letters)
lvl10720-TurquoiseAuthorAnswer
20-Turquoise
     Many thanks, again.
          Best Regards.
               Loi.
You may also use a functional approach and use CreateMesh()
20-Turquoise
Thanks again, Werner. I guess this approach is better than the prior approach.(avoid hitting the wrong key-stroke)
