May 10, 2018 8:17 PM UTC
How to simplify exponents of exponents
When doing symbolic math, sometimes the result has exponents of exponents, for instance
(x^2)^(3/2)
A simpler form for this expression would be x^3, but even using "simplify,max" does not change the form of the  result. "combine" and "expand" don't help either.
Is there any way to get Matchcad to simplify this expression?
Werner_EAnswer
May 10, 2018 8:49 PM UTC
(x^2)^(3/2) = x^3 is true for x>=0 only, not for x<0.
And if x is non-real, the square root ()^.../2 has two results, not just one like x^3.
Mathcad takes that into account and will only simplify to x^3 if you tell it with the "assume" that x is positive (that implicitly also tells MC that x is real of course).
Werner_E25-Diamond IAnswer
bdjinsd1-VisitorAuthor
May 11, 2018 12:26 AM UTC
Ah, that helps. Thanks!
