How to solve this pipe flow problem
I try to solve a pipeflow problem but I have problems in doing so as I have no experience in this type of problem. In the first part of the sheet you will find the known variables. In the second part I try to calculate the different pressures. However, I have problems in setting up the equations. Would anyone be so kind to help me with this? The file is made with MC15
Werner_EAnswer
1) V1, V2 need to be defined
2) All equations except the top 4 should be normal assignment above the solve block.h.exit:=..., etc.
3) You should solve for P1, P2, P3 AND P4 as well (4 equations, 4 variables to solve for)
4) You need guess values for P1 .. P4, not for other variables.
Werner_E25-Diamond IAnswer
FDS13-AquamarineAuthor
Thank you Werner that solved the issue
I have one additional question. How could I calculate "theoretical" V when forcing P1 to be 0 mmHg and by changing Pc? For clarity I have put both in purple. Sorry, for these obvious questions.
