how to use controls to switch inputs
- 11 replies
- 4712 views
- Translate All
hi,
i'm sure this is an easy question for a lot of you. i don't understand the help or built in examples for this topic. i have a variable i want to switch using some type of control. i can't figure out how to do it. i got the slider switch working, which is nice. but the other controls i can't figure out. i attached the matchad 15 worksheet. not interested in a prime solution, if there is one.
there are five choices for the variable z. i have just been manually typing in the choices. if you could show how this would work for as many of the controls as possible, i would appreciate it. it's something i'd like to learn how to do.
thanks
