6-Contributor
How to use the symbolic engine to derive an equation?
I attached a simple example (clark transformation). Assume that I do not know the relationship between Uabc ,Ualpha and Ubeta. How can I derive the final transformation from the known equations? Thanks.
The file was writen in Prime 8.
CornelAnswer
ttokoro
Before define ualpha and ubeta, Prime only can do below.
t.t.
6-Contributor
The picture shows the known five equations. I want to use uabc to represent ualpha beta. How to derive the transformation matrix if i do not know this?
23-Emerald V
Are you looking for something like this?:
Sorry, that can only be done in Mathcad 11¾ .
6-Contributor
Yes, that is it. I thought prime could do this. Thanks.
