May 29, 2013 1:57 PM UTC
i could not open my .xmcd files
Hi, I have 30-days Mathcad Express Prime 2.0 . I have to open my .xmcd files but i could not because there is not active the Converter XMCD, MCD. Please help me.. Thanks...
Werner_EAnswer
May 29, 2013 7:54 PM UTC
Here you are.
Be prepared that conversion usually is not perfect and often requires some post-editing.
May 29, 2013 2:43 PM UTC
Ridiculous as it may sound, but to convert files to Prime format, PTC forces you to install a full Mathcad 15 (latest release) on your system. You will have to download and install a 30-days trial of Mathcad 15, too.
Be prepared that (I guess) you will lose the ability to convert files after the trial period, as MC15 will refuse to load after that time in contrary to Prime, which falls back to a crippled version called Express.
If you have a licensed MC14 or an older release of MC15 installed on your system, save your license file, as the installation of MC15 will remove your installed MC.
If you don't have too many files to convert, you may consider posting them here and I'm sure someone will convert them for you.
Mar 19, 2014 2:22 PM UTC
May 29, 2013 7:26 PM UTC
Werner_E25-Diamond IAnswer
May 29, 2013 8:00 PM UTC
Thank you
Jan 16, 2014 9:48 AM UTC
I have the same problem using Prime 3.0
Could someone please convert this file for me?
Thanks in advance!!!
Jan 16, 2014 4:58 PM UTC
Here is what the converter did with your file as well as a pdf of how it should look.
Any good reason for using Prime?
Jan 17, 2014 7:25 AM UTC
Werner Exinger wrote:
... Any good reason for using Prime? ...
You can use Prime Express without restrictions of time.
Jan 17, 2014 2:05 PM UTC
Not i but I
Jan 17, 2014 3:14 PM UTC
Valery Ochkov wrote:
Not i but I
Huh!?
