included sheet generating error
using Prime 2.0.  i "include" a sheet with a simple program (attached).  it works fine in the original sheet but the sheet that is trying to "include" it complains that there is an error in this sheet.
There is no attached file in your message.
bsimpkins1-VisitorAuthor
oops.  here's the sheet.
When I open your sheet I don't see any error.
We can't play around with the sheet cause we are missing the excel file.
What do you mean that you are trying to "include" the program somewhere else? Where?
Post the sheet, that is throwing the error.
aha!  i figured it out.  i had the "included" sheet in another directory so when it was read in the new sheet, and mathcad attempted to follow the path to the excel sheet, the path was no longer correct.  i will need to put the full path in.
