7-Bedrock
Inequality Help
Hello, sorry if this isn't the correct place to post but please help me out. I have the following eqn.
X:= a + b <= c + d = 0
How do I get X to be defined as the lesser of the two. I want it to be defined as C+D if it is smaller, Not 0 or 1.
It is only returning 0 or 1 depending on if the statement is true or false.
7-Bedrock
Thanks for the response but a better solution I figured out is as follows:
X := if(a+b<=c+d,a+b,c+d) This allows the inequality to return the value instead of 1 or 0
23-Emerald V
Then you probably want:
X:=min(a+b, c+d)
X will get the value of a+b if that is smaller than (or equal to) c+d.
LL_103366397-BedrockAuthorAnswer
7-Bedrock
23-Emerald V
Your IF statement is equivalent to the use of the min() function. The min() function is more compact.
