Dec 2, 2024 12:00 AM UTC
Inquiry About Opening Mathcad Prime Files in Multiple Windows
Dear all users/Sir,
I would like to know if it is possible to open Mathcad Prime files in multiple windows. Whenever I open a new file, it appears in the same window. Having the option to open files in separate windows would make it much more convenient to work on multiple files simultaneously.
Your guidance on this matter would be greatly appreciated.
Thank you for your time and assistance.
Ikbal
terryhendicott
Dec 2, 2024 12:34 AM UTC
Just open multiple instances of Prime using the start icon/shortcut not by selecting files.  Then in the separate instances open separate files.
Note additional instances of Prime windows will be exactly on top of each other when you open another instance and the windows need to be separated.
Cheers
Terry
terryhendicott
Cheers
Terry
Ikbal5-Regular MemberAuthor
Dec 2, 2024 12:52 AM UTC
Thank you so much.
