Jun 3, 2026 4:10 PM UTC
Integral gives solution with limit function
I want Mathcad Prime 11.0.1.0 to solve a simple exponential integral and it returns a limit towards infinity no matter what kind of assumptions I give it. A negative exponential should always go to 0 for x towards infinity when tau is real and positive.
If instead I substitue manually a new variable x
the integral is solved correctly
How can I convince Mathcad to do the same ?
23-Emerald V
Jun 3, 2026 5:47 PM UTC
Tau being real and positive could still mean it is very large, defeating the speed at which the exponential drops to zero, especially in combination with the multiplication of it with the exponential.
After your substitution, there’s no doubt that x will go to infinity and the exponential always wins from the tau it is multiplied with.
Note that you did not actually make that substitution in your original integral. If you had, It should have rendered something like:
Jun 3, 2026 7:43 PM UTC
Why do you think that “=positive” is a valid modifier? I could not find it in the list of modifiers in the Prime help. Try “>0” instead.
Can’t check with Prime but here is the result of Mathcad 15 (using muPad as symbolic engine)
You may try if “assume, tau>0” does the job better than your “assume, tau=positive”.
You may also try to add “simplify” or even “simplify, max” if it does not help.
23-Emerald V
Jun 3, 2026 9:02 PM UTC
Maybe because it works in Mathcad 11:
Jun 3, 2026 11:46 PM UTC
But not in MC15 and probably not in Prime (‘real’ is a valid modifier in both, but ‘positive’ obviously not).
Jun 4, 2026 6:17 AM UTC
Seems to be the division that it doesn’t like.
Alan
Jun 4, 2026 10:52 AM UTC
So you mean that “assume, tau>0” does not work in Prime with the original expression?
If that’s the case i would call it a bug which should be reported.
Jun 4, 2026 11:24 AM UTC
Yes, it doesn't work (I used version 12).
TarekL4-ParticipantAuthor
Jun 8, 2026 10:14 AM UTC
Thanks to all for your comments and comparisons.
I remember vaguely when I had still Mathcad14 (don’t have it anymore), that the solution was useful like your report for versions 11 and 15, as I expected (copied from above):
And mathematically there’s no reason why the solution should involve a limit when switching between f and tau
as long as both are finite and larger than 0.
So I would call it a bug.
