Integrate a function between varying limits and return the result as a vector
I would like to integrate a function between a certain number of pairs of limits. The number of pairs is set by a variable, n.th. I'd then like to return the result as an n.th x 1 vector. Could anyone help please?
Please see attached.
Many thanks and kind regards
Werner_EAnswer
And if you want it to be done by a more generic function, you could do it that way:
Worksheet attached.
You may use a range variable to do the job
Werner_E25-Diamond IAnswer
Worksheet attached.
AATaylor1-VisitorAuthor
Even better! Thanks!
