Integration
Hi to all,
I am further experimenting with my Naval Architecture calculations in MC.
In the attached MCP3 file, can anyone tell me why the integral returns what seems to be an infinite number of answers when the answer I expect to get is 50m^2?
Andy.
Your integral goes to WL(y,T,phi).  y is defined as a range variable of 100 points, so it returns 100 results.
Replace y with a single value (5 m or similar) and you get one answer (50 m^2)
awibroe1-VisitorAuthor
Any ideas how I can set this up to integrate area under WL?
As per attached where phi is not 0.
23-Emerald I
I don't like your setup, but
One rule you should consider is NOT TO USE range varaibles for calculations!!
Use ranges for plotting, use ranges for indexing vectors and matrices and uses ranges for loops in a program. But please don't use ranges for anything else unless you really want to run into troubles!!!
Top advice Werner. I defined range variables to allow visualisation of the problem.
I’m still not quite there with a solution though. Ultimately I want to integrate the space inside function St(z) i.e. to the left of the vertical blue line. And up to a height of the function WL(z) ie the black line which may not be horizontal.
@awibroe wrote:
QuoteTop advice Werner. I defined range variables to allow visualisation of the problem.
But you did not leave it at that. The problem in your initial question, the reason you got the strange result which puzzled you, was, that you also used those ranges, which you defined before for plotting, in your calculations.
