Interchange more than two colums between two arrays
Hi, I also know how to interchange more than two columns between two arrays, as shown in the attached file.
Thanks.
Werner_EAnswer
For whatever it may be worth here is a slightly improved version with the benefit that the same columns could be used multiple times:
MC15 sheet attached
May like that (error check is only implemented rudimentary):
Mathcad15 sheet attached
Werner_E25-Diamond IAnswer
MC15 sheet attached
I really appreciate  the solution , thanks
