Is there a fast way to analyze 100+ images in Mathcad?
  • April 10, 2013
  • 7 replies
  • 3483 views
Hello guys,
I would like to ask you if there is any tool in Mathcad that allows fast analysis of images? I have a set of couple of hunderds of photos describing a certain process. Each photo should be converted to a matrix and then some mathematical operations should be performed. I know how to do this one by one, but it is time consuming. Is there any option in mathcad to analyse .gif file type? Or any other easier and faster way?
Thanks!
Best answer by Werner_E
Find attached a possible solution to your image processing automation (with thres=140 in absence of other information) and at the end an answer concerning your last question.
As you know how to do it with one pic you should post the worksheet here.
Its hard to give advice without knowing what you intend to do.
Generally spoken you would turn the operations you do on your pic into a single function dependent on the pic and then write a routine which takes all the pix in a directory or of a list and processes them automatically one by one.
PS: AFAIK Mathcad supports the GIF-format. Did you look at the E-book on Image Processing for information? I am assuming you are using Mathcad, not Prime!?
naz_or1-VisitorAuthor
Here is the link that is related to single image processing (my post).
http://communities.ptc.com/message/198410#198410
I agree with you. It seems like only available possibility. I have one quick question: if i have a (x,y) data set, what function should i use in mathcad to expell all (x,y) pairs if x or y match/dont match certain criteria?
P.S. Yes, I am using Mathcad. I will look into image processing pack.
Thanks!
May be pictures from this article help you:
http://twt.mpei.ac.ru/ochkov/Mathcad-15/SolveImage.html
PS
Russian + Google translator = English/Сербский
