May 25, 2017 12:59 PM UTC
Is there a way to add conditional formatting?
How can I add a conditional formating to mathcad sheet similar to what excel. Where the results of a results checks highlights in different colors depending on the results check (ie. if 1 > 0 highlight as green, and if 1 < 0 highlight as red)?
23-Emerald V
May 25, 2017 3:03 PM UTC
Export your results to an excell object and have that object displayed in your mathcad sheet may be a way.
I've never experimented with it in this way though.
What version of Mathcad do you need this for?
aannaim1-VisitorAuthor
May 25, 2017 3:05 PM UTC
I'm working with MathCAD Prime 4.0
May 25, 2017 3:46 PM UTC
What you are looking for could be done in Mathcad 15 (and below) using scripted components - Text boxes.
In Prime this feature is missing.
Apr 18, 2018 6:52 PM UTC
This is a much needed feature.
23-Emerald V
Apr 18, 2018 7:48 PM UTC
I'm certain there are other features that are much more needed. And they do not get delivered either.
Aug 20, 2019 6:45 AM UTC
The following works in Mathcad 15:
