Is there a way to plot a function of (x,y) like ezplot in Matlab?
Hi, guys
I want to plot the function:
f(x,y) = x^2 + y^2 +x*y - 3600, bounded with f(x,y) <=0;
Just like the graph shown below:
The figure is plotted with ezplot in Matlab.
function a=elp1(x,y)
     a=x.^2+y.^2-60^2-x.*y;
end
figure(1)
h1=ezplot('elp1',[-90,90,-90,90]);
So far I haven't figured out an alternative in Mathcad that can do this.
Could you help me with some ideas?
Thank you very much!
Best
Shawn
One general method for any f(x, y)
-MFra-
Hi Shawn Fan,
your function is a quadric which can be plotted as follows:
the 2D plot looks like the intersection of the quadric with a plane parallel to the xy plane (z=f(x,y)=a).
For me this is the most simple and basic method ...
Best Regards
FM
Lace
sfan1-VisitorAuthor
Thank you Valery!
This is very helpful!
Could you give me some hint on how you apply the approximate equal?
I use a Greek beta letter to substitute your approximate equal sign since I don't know how to input it in Prime.
When I type f(x,y) and the beta sign, Mathcad will always place a "." in between the two terms, making that beta a variable rather than an operator.
Best
Shawn
An ingenious method implemented by Viacheslav  N. Mezentsev to do implicit 2D and 3D plots (even for Prime) can be found here:
Re: implicitplot2d()
sfan1-VisitorAuthor
Thank you so much Werner!
This function is very quick!
I will refer to Mezentsev in my homework.
Thank you!
Another method from Viacheslav A.Tarasov. It works in MC 15 but does not work in the Prime (why?).
Viktor
