is there any way to open protected area if forgotten password?
I want to know that is there any way to unlock protected area if someone forgot password for locked area.
Prashant Pandarkar
23-Emerald V
For an area in Prime, especially in the more recent versions, the protection is supposedly very good, hence: no way to crack.
Advice: Don't forget the password for a locked area.
Yes, protecting area is very good feature for prime.
but someone may get forgot or may left organization so want some workaround or solution so at-least we can recover existing design sheet instead of making it as scrap.
- Prashant Pandarkar
-MFra-
You should always make an unprotected backup copy of each file.
Depending on which version of Mathcad was used to create the worksheet, it may be possible to open the area. As others have noted, if it was created in Prime though, then the answer is no.
