IsMissing function
Greetings,
Is there a built-in function "IsMissing" in mathcad 14?
if not, what do I have to do?
You can try to create the user function!
23-Emerald V
What should the "IsMissing()" function do?
What parameter(s) does it get, and assuming its result should be Boolean (TRUE or FALSE), when does it result in TRUE?
Program it yourself: IsMissing Function
23-Emerald V
Unfortunately it is not possible to (user-)define mathcad functions with optional arguments. Neither with mathcad statements, nor via user programmable (.DLL) functions.
So the IsMissing function you are pointing to appears to be useless.
