Issues with including multiple sheets in a summary sheet.
- 3 replies
- 1521 views
- Translate All
Hi there,
I have a couple of calculation sheets and I am trying to incorporate them into a summary sheet.
If I include sheet 1 first, it returns the valves from that included sheet.
However if I include sheet 2 below it some of the values are failing saying that the variable is undefined, however it clearly is. (Summary 1)
If you look at Summary 2 however I have reversed the order of the included sheets and the opposite happens ?????
Has anyone got an idea as to what the issue could be??
Its annoying because it says that there are errors in the worksheet but there isn't.
I am actually trying to summarise 6 sheets, these are just two of them .
Cheers
