Iteration with several equations
Hello
I should somehow solve an parameter with iterating several equations simultaneously.
In the attached sheet are to constants, equations and the "to be solved" parameter.
The problem is that I don't know if "Given" "Find" system works for this kind of a problem...
I would prefer a solution using programming i.e. with "Add line" operator,
but I don't know how to program this.
Any help is appreciated.
23-Emerald I
A solve block should solve this, but you've got several problems:
  1. You have some variables with units and there are numbers in your equations without units.  In several places you are raising stress (Pa) to fractional powers.  m_parameter adds a plane number to a number with units (which you cannot do.)
  2. You have an exponential {exp((1.63-9.7/FC-15.7/FC)^2} which evaluates to a constant (3.521), why carry such a complicated expression; or is it wrong?
It looks like you're trying to program an iteration.  I would assume, then, that you would like delta q to go to zero (?)  Can you write simply the condition you want to be an equality?  That's what you need for the solve block.
It is possible to iterate (using a very old Mathcad construct.)  Attached is a Prime 4 file and its pdf.
See the attached for how to structure the system in Mathcad.  However, the results cannot be trusted unless I have guessed the right units for your m.parameter function. You will need to adjust this appropriately.
Alan
Hi Alan
Your solution appears to work fine for the request that I had. I attached a computation file and
a pdf with the values using the correct units and the results seem to match with the graph.
The reason why I need an automatic iteration is that the computation should be done to a large number
of input values. The sheet with the large vectors can be found as attached.
Could you or someone else help to get the iteration program to work for a large number of these input values?
Thank you in advance.
23-Emerald V
You can define the result of the solve block as a function. That should allow you to use the same solve block for any number of inputs.
Here is a very small example that should illustrate the method:
