Jacobian Calculation Crashes for System of ODEs
- 4 replies
- 2036 views
- Translate All
I have a program that works (PPPWorks_12_19_2020) for solving a system of odes using Radau with the Jacobian (I am using this because the solutions have peaks which are slightly better resolved with this choice). I made what I thought was an innocuous change (PPPNoWork_12_19_2020) adding the equation dA=0 so that I could set the value of A in the initial conditions. Now the calculation for the Jacobian grinds away for a while, then crashes MathCad. What did I do wrong? Maybe I now have two many equations d(...)= 0 for setting parameters in the IC? Any suggestions?
