Javascript calculation in MAthcad
I have created some scripts to change some inputs in Mathcad and read the Output fields but I am finding troubles as the file is not fully updated when I read the outputs. I am trying to calculate with Syncronize() but overwrite my inputs and I would like to save the file but I am not finding the way.
Thank you
Mathcad Prime 8.0.
I have found a partial solucion that is overwrite the file.
worksheet.SaveAs(fileSystemObject.BuildPath(dirScript,"file.mcdx"))
I have to check in deep if all the outputs are right but at least the outputs looks better.
terryhendicott
The close statement is a function associated with the worksheet variable.
From the help file
How to create a worksheet variable
var worksheet = mathcad.Open(fileSystemObject.BuildPath(dirScript,"test.mcdx"));
Close(SaveOption)—Closes the worksheet if it is open in PTC Mathcad Prime.
SaveOption
SpSaveChanges—Force to save changes, without prompting the user, before the worksheet is closed.
spPromptToSaveChanges—Prompt the user to save changes before the worksheet is closed.
spDiscardChanges—Discard all changes and close the worksheet.
The special behavior for a new and non-modified worksheet:
The worksheet is closed without prompting the user, even if saveOptionArg is set to spPromptToSaveChanges.
The worksheet is closed without prompting the user, even if saveOptionArg is set to spSaveChanges.
Please specify which version of Mathcad you are using.
JV_104679341-VisitorAuthorAnswer
Mathcad Prime 8.0.
