License Path Issue
Hi, I'm a student and am unable to locate the Mathcad Prime license required to dual authorize the Mathcad 15 program. Per PTC instructions this file is "MathcadPrimeLicense.dat" in "C:\ProgramData\PTC\Mathcad Prime\license\directory" and similarly in forum discussions has been listed as "C:\ProgramData\PTC\Mathcad Prime\license\MathcadLicense.dat". Presently, althought I have successfully licensed Mathcad Prime, there is no "*license.dat" file that I can locate on my computer and the only files under the "C:\ProgramData\PTC..." directory are "Windchill sharepoint products" and 'PTC places NamespaceShellExtension". All other files reside directly under the "C:\ProgramData\Mathcad..." directory, but, nowhere can I find the license file.
I purchased an HP Laptop with Windows 8 just yesterday (subsequently upgraded to the Win8 "pro" version) specifically to run Mathcad for a class. I have homework due soon, so, any help I can get in getting Mathcad 15 running would be most appreciated.
Thanks!
In Mathcad Prime2 click on the yellow M in the upper left corner, chose Mathcad options and then go on tab license. You should see what kind of license you own and there is a field "file" and you should see the path to your license file there.
Concerning your homework - Mathcad 15 works 30 days without license in evaluation mode which is not restricted. Rumour has it that you even can have a second 30-day period before final game over, but I never have tried, so it may be a myth.
Thank you. You are exactly right. By copying and pasting this file name into Mathcad 15 I was able to get up and running. Apparently my problem is due to unfamiliarity with Windows 8 - whether I use Explorer or the Search charm I am unable to find the file folder that begins "C:\ProgramData\..." or a file anywhere on my C: drive named "...MathcadPrimeLicense.dat" so browsing for the file was unsuccessful. Since the copy/paste worked, however, I'm good. Thanks again!
Glad to got it running.
One more reason for me to stay happy with XP 😉
Have Mathcad 13 and worked on old computer now dead
Loaded on new computer but doesn’t work. It doesn’t open .
Any suggestions
23-Emerald V
What OS and bitness? What kind of Mathcad 13 (single user or enterprise)?
Windows 10 but has x86 and single user.
Ran previously on old computer on xP service pack 2
