Werner_EAnswer
So what should happen with the values in q which are outside the limits?
Do want to set them to the lowest or hightest value allowed or do you rather want to delete them from the vector?
From the attempt you posted I looks like you want to delete those values.
One way to achieve this is
Werner_E25-Diamond IAnswer
I want to delete the values outside the limits
Thanks a lot
