Linear programming using minimize limitations
  • June 14, 2012
  • 3916 views
Linear programming using Minimize is very limited in term of the size of the problem that can be addressed. number of variabls and constraint space dimension are very small. Is there any plan in making this feature more robust and scalable ?
Sorry, how many variables (not "very small") do you use or would like use in Mathcad?
pnav1-VisitorAuthor
hi valery,
well for instance for the problem :
f being a function of u
given A.u=c
with bounds on u
solution := Minimize(f,u)
if Dimension of A is less than 50x75 solution is obtained,
when dimension for A is in excess of 50x75
then solution becomes red and showing (when you point onto it) : This variable is undefined...
I think the matrix 50x75 in this problem is not so bad for Mathcad!
Can you attach the file or describe the problem?
A propos.
50 is the maximal number of arguments of the function Find, Minimize and others with variable number of arguments.
