Loop Conversion from MathCAD15 to Prime9 Variable Issue
When I ran the conversion tool it converted mathcad15 statement
to Prime 9 Statement
which only works if a precede it with an additional variable definition
where NPS1 is already defined.
Any ideas why this additional variable statement is required for Prime9 but not Mathcad15?
LucMeekesAnswer
23-Emerald V
What you are trying to do is equivalent to:
At the time of creation of the vector, it's element values are unknown.
I guess Prime was built as an even more lazy machine than Mathcad, although, in Mathcad this doesn't work either:
LucMeekes23-Emerald VAnswer
23-Emerald V
GregH4-ParticipantAuthor
Hello Luc, thanks for the review and explanation. It makes sense to me that the vector creation was the issue. They must of handled it differently in MC15 with the if/otherwise statement. When Prime 9 did the conversion it changed this throughout the program to the new if/else format.
If I recall correctly, Mathcad 15 first checks the condition and then calculates the appropriate fork. The other fork is not handled at all and thus the error didn't happen. Prime checks both forks and sees the error.
